I decided to see if the ZR2 skidplates would work on my 2017 LT 2.8 CCLB.
Im sure that the superskidz are a great product and they look bomber but I wanted to experiment. I got both front skid plates from GM parts direct (no affiliation just the cheapest I could find). For both it was $220 shipped.:smile2:
I crawled under the truck and ripped the stock plastic "sheild" and diff guard off.
The rear skid plate that goes under the diff and oil pan bolted up quickly in existing holes.
I held the front skid plate up and started marking. I had previously removed the air dam so only had the bottom of the bumper to contend with but as you will see you can make it work with the air dam on too. I mad some marks and started trimming. The Skid is aluminum and so I used a jig saw with a metal cutting blade then cleaned up the cuts with a flapper disk on a 4" grinder.
Made the initial marks then started cutting.
Got the first cuts done and there were still some areas of contact. Cut some more. There are brackets on the bumper either side of the crossmember the skid bolts to that are in the way of the "wings". I didn't feel I needed the wings so they were cut off and notched around the brackets.
The "nose" of the skid can go up and in the bumper after you cut off the wings but this complicates installation and removal so I cut off a portion of that as well. I left a little of the nose which has a bend to add strength to the front (not needed as there is a cross member there).
All cleaned up it looks and fits great. Installation is easy on and off but I shouldn't need to take it off unless Im tearing up the front end.
You can take more care to keep it shiny but it came with scratches from shipping and I plan on scratching it more so didn't worry about the added rub marks from cutting.
So, it can be done in about an hour of cutting with common tools. Pics attached of the process and installed. There are 2 extra bolts from the disassembly so those can be used at the rear of the rear skid...bonus not having to buy bolts.
