Rear locker will work in 2WD?? I'm guessing not.....probably only in 4WD.I'm curios as to why? The rear locker will work anytime, offroad mode needs to be used for speeds above a certain amount (Can't remember what off the top of my head). The front will only engage in 4lo. I don't think I want the front locked if I'm going faster than 4lo will allow.
Wow, that's surprising actually...... impressive that they set it up that way.Rear works during 2wd normal driving below 30 mph if you activate it. Off-road mode allows you to use it at any speed in 2 wheel drive. Front needs 4 low engaged to be activated.
That's the one thing we didn't do in our jeep. Believe me......we talked about it but never pulled the trigger. Atlas all the way.... We had a friend of ours who had an Atlas and he'd spank us everytime.Let's just install a twin stick t case!
The reason begging they factory switches aren't actually just a switch, but are run through the PCM
