I got the itch for more lighting. The LED headlight replacement are nice but not quite as much as I was wanting as for out put. The only somewhat reasonable spot on a [email protected] is in the grille. I had to cut out a couple vertical crossbars, but I wanted to leave the two middle ones for support. I could not find a good curved light that was not to wide so I went with the Rigid SR 30". I wired the relay trigger wire to the high beams so it turns on and off with the high beams. I do have an override switch if I want to run without it.
