1 - 11 of 11 Posts
Hi all, first post.
I did some searching and I noticed there are maybe two guys who have installed ARB bumpers on their ZR2s. ARB’s official line is that it doesn’t fit and don’t do it because of the weight on the DSSV shocks.
My questions are how much modification is required to get it to fit, are there any detrimental effects on the suspension that have been noticed? Peak suspension has a couple rates for their coil overs and eibach springs, would stepping up to a stiffer spring help?
Thanks in advance,
Oh and I like pics so if you have any ARB install pics post em up!
Here’s a pic of my virgin ZR2
377813
do like some, they install the diesel springs
like this one? opps that is a z71
377814
Hope you have someone good with fabrication and approximately a week without your truck
That doesnt make a whole lot of sense. Sure, adding a new bumper changes the weight in the front, but maybe 100-150 pounds, depending on if you're putting a winch on it as well.
Thats like saying, dont drive around with any fat people.
I know the shocks in the ZR2 are expensive but.....are they trying to suggest that carrying 2 bags of rock salt in the back will ruin the back shocks as well?????
Discussion Starter #9
No bracket to be made everything you need for the install is in the box, a lot of cutting up front is required and if you install a winch additional cutting is required
Ok Thanks, can you elaborate as to what was cut?
Midwest requires cutting of the plastic in front of the rad in the diesel in order to fit their winch cradle as does CBI for their new full bumper depending on the winch fitted, as well as the plastic on the old bumper and trimming of the grille.
More to the point, was there any sheet metal cut or mods to the rad cradle to mount it up.
Thanks again.
Don’t know if you still have questions or if you’ve gotten one installed yet. I installed mine a couple months ago, I love it. I swapped out the front grille to a letter bison style grille, so I didn’t have to cut up the grille. If you have any questions feel free to PM or message me on Instagram K5daniel.dp
382698
1 - 11 of 11 Posts
