These aren't too expensive, but new and they work.Hi I'm looking for a set of TPMS sensors to put in my winter wheels. Anyone have a set they would be willing to sell for cheap?
I have the part number 13581558, would these work as well. I found them for cheaper than the sensor you postedThese aren't too expensive, but new and they work.
ACDelco 13598772 GM Original Equipment Tire Pressure Monitoring System (TPMS) Sensor Kit with Sensor, Stem, Bolt, and Cap https://www.amazon.com/dp/B014VZFQAS/ref=cm_sw_r_cp_apa_PJDWzb7P45MN7
Sent from my SM-G950U using Tapatalk
When I searched, these showed as a newer part number. I purchased one for a full sized spare and it worked. I figure either will work then.I have the part number 13581558, would these work as well. I found them for cheaper than the sensor you posted
I need the whole sensor with valve stems and allDo you need the valve stems and the sensors or just the sensors by themselves?
