1 - 12 of 12 Posts
Just a quick intro. I've had a 2005 CC 3.5 for 12 years and I'm passing it to my daughter. I know this isn't the easiest vehicle to find but it is one that I actually want. Any help would be appreciated.
here ya go, about 10 miles from me
2012 Chevrolet Colorado 2LT Crew Cab 4WD
Come see this 2012 Chevrolet Colorado LT w/2LT. Its Automatic transmission and Gas V8 5.3/232 engine will keep you going. This Chevrolet Colorado comes equipped with these options: WHEELS, 18 X 7.5 (45.7CM X 19.1 CM) CHROME ALUMINUM, TRANSMISSION, 4-SPEED AUTOMATIC, ELECTRONICALLY CONTROLLED WITH OVERDRIVE (STD), TIRES, P265/65R18-112S ON-/OFF-ROAD, BLACKWALL, SHEER SILVER METALLIC, SEATS, FRONT BUCKET with adjustable (up/down) outboard head restraints and map pockets on seatbacks (STD), REAR AXLE, 4.10 RATIO, LT PREFERRED EQUIPMENT GROUP Includes Standard Equipment, LPO, CHROME GRILLE AND INSERTS, LICENSE PLATE BRACKET, FRONT, and GVWR, 5500 LBS. (2495 KG).
Additional Information
LICENSE PLATE BRACKET FRONT,LT PREFERRED EQUIPMENT GROUP Includes Standard Equipment,AUDIO SYSTEM AM/FM STEREO with CD/MP3 player seek-and-scan digital clock auto-tone control Radio Data System (RDS) automatic volume and TheftLock (STD),GVWR 5500 LBS. (2495 KG),SHEER SILVER METALLIC,LPO CHROME GRILLE AND INSERTS,ENGINE 5.3L V8 SFI (300 hp [223.7 kW] @ 5200 rpm 320 lb-ft of torque [432.0 Nm] @ 3600 rpm),ENGINE BLOCK HEATER,REAR AXLE 4.10 RATIO,WHEELS 18 X 7.5 (45.7CM X 19.1 CM) CHROME ALUMINUM,SEATS FRONT BUCKET with adjustable (up/down) outboard head restraints and map pockets on seatbacks (STD),TRANSMISSION 4-SPEED AUTOMATIC ELECTRONICALLY CONTROLLED WITH OVERDRIVE (STD),TIRES P265/65R18-112S ON-/OFF-ROAD BLACKWALL,EBONY LEATHER-APPOINTED SEATS includes 8-way power driver seat adjuster 6-way power front passenger seat adjuster heated driver and front passenger seats with power lumbar control and adjustable outboard head restraints,ALTERNATOR 145 AMPS,Keyless Entry,Power Door Locks,Power Mirror(s),Power Windows,Auto-Dimming Rearview Mirror,Tow Hitch,Locking/Limited Slip Differential,Four Wheel Drive,Tow Hooks,Tow Hitch,Power Steering,ABS,Front Disc/Rear Drum Brakes,Chrome Wheels,Tires - Front On/Off Road,Tires - Rear On/Off Road,Conventional Spare Tire,Fog Lamps,Privacy Glass,Sliding Rear Window,Power Mirror(s),Intermittent Wipers,Bed Liner,AM/FM Stereo,CD Player,MP3 Player,Satellite Radio,Requires Subscription,Bluetooth Connection,Bucket Seats,Pass-Through Rear Seat,Rear Bench Seat,Floor Mats,Floor Mats,Leather Steering Wheel,Adjustable Steering Wheel,Engine Immobilizer,Telematics,Cruise Control,Telematics,Navigation from Telematics,A/C,Power Outlet,Auto-Dimming Rearview Mirror,Passenger Vanity Mirror,Traction Control,Stability Control,Daytime Running Lights,Driver Air Bag,Passenger Air Bag,Passenger Air Bag Sensor,Front Head Air Bag,Rear Head Air Bag,Telematics,Telematics,Navigation from Telematics,Tire Pressure Monitor,Child Safety Locks
i would get this black one, it looks just like the truck I had but withh the v8
unless you like white
The white one looks nice and I like the 4.10s
The white one is about 3500 over on price and I'm not really interested in paying that much over. If there any more out there I would love to see them
did you look in your area or the whole country on the link i posted? what area do you live?
over on your or Kelly's price? The v8 is a hot comodity a few thousand more then an I-5 in same conditions, may want to look for a H3T
I'm located in Beaumont Texas.
well here is 13 of them, I guess you already check these all out? one right around the corner from you
why a V8, pulling a big car trailer? that old V8 gets about 12mpg
13 HT3's with V8's if you need a V8
you probably already checked these out too. fyi: a H3T is a canyon/colorado with a different body
Discussion Starter #11
I do pull my boat and occasionally a trailer. The I5 has done fine but I've always wanted to swap the truck and I figured I should get what I always wanted.
Discussion Starter #12
Zero interest tbh. They are uglier than sin lol
1 - 12 of 12 Posts
