1 - 4 of 4 Posts
First off sorry about the new thread, i just posted one about an hour ago and i answered my last question. so this should be my last question .i searched the web and found the Manual so here is the link.
http://www.retrevo.com/search/v2/jsp/do ... +ksc-wd250
now my final question is, how do i connect the 2 yellow power wires, it says go to the battery? i am completly new to all of this please help me out.
run a wire of the proper gauge from the battery to it. fuse the wire with the proper fuse- fuse it for the capacity of the wire NOT for the component.
you can use a ring terminal to connect to the battery. there is an unused stud on the positive battery terminal, you will need to find a nut and washer for it tho.
what does the orange wire do that connects to the headunit?
is that the power, if so could that be tapped into?
you should be able to tell which one is power and ground the ground almost always black and power is usually yellow or red but the ground wire and the one running from the battery are a little bigger than the rest if ur orange is same size as the rest its most likely the accesory wire
1 - 4 of 4 Posts
