1 - 5 of 5 Posts
im loking at a procomp wheel that with these specs 17x9, 6 on 5.5 Bolt Pattern
Backspace = 4.75 in.
Hub Centric = No
Max Load = 2200lbs
Offset = -6mm
With this offset how far would they stick out?
It'll probably stick out about half an inch, I have a 0mm offset and it barely doesn't stick out at all. Depending on your body kit, if you don't have Z71 flares those suckers are gonna stick out a lot
31 X 10.5 X 15 R
With the following rims.....
15 X 8
4.75" Backspacing
+6 MM Offset
6 X 5.5 Bolt Pattern
Look at pics in my profile.
Keep in mind that the stock offset is +30 or 31 MM, and if your going to -6, then you can get an idea of how much its going to stick out, not to mention the other factors.
i dont have any fender flairs bc im waiting for glassworks to release prerunner fenders in march. but you think that they would stick out far on the stock fenders?
My estimation is about 1.2 inches over stock
1 - 5 of 5 Posts
