Was under my dash to look at installing a brake controller. Founds these plugs. Anyone know what these are for? 2020 Canyon, 3.6L, Crew, WT. Thanks!
Also been wondering what this small panel is. I pulled in off. Nothing behind it. Looks like a credit card slot at an ATM.
Are they just left over from a wire harness? I have a 2WD.Brake controller and 4x4 switch.
Not so much left over. All (or most) main wiring harnesses are the same. If the truck is not optioned with the particular option, it's just not used. Much easier to manage one spec of harness, from a mass production standpoint.Are they just left over from a wire harness? I have a 2WD.
Blank plate for the connectors or the toll pass slot ?Do you know where I could get a blank plate that will for it that?
ARCowboy is yanking your chainThat same panel except just blank. No slot. I’m thinking I could use that for a brake controller install and put the control right there. Having a hard time with internet searches. Thought I’d see if anyone knew where to find trim parts like that. Thanks!!
It is, on brake controller vehicles. On others it's the toll pass slot lol.ARCowboy is yanking your chain. The panel with the slot in it is where the factory brake controller sliders would be.
Actually I think that the insert are two different parts. With the factory trailer brake controller the slot is flush with the dash and doesn't have the slight indent.It is, on brake controller vehicles. On others it's the toll pass slot lol.
No, he is right.ARCowboy is yanking your chain. The panel with the slot in it is where the factory brake controller sliders would be.
It lights up? I never noticed, I have that control on mine but it's basically hidden behind the steering wheel so I've never seen it at night.Actually I think that the insert are two different parts. With the factory trailer brake controller the slot is flush with the dash and doesn't have the slight indent.
Yes, it appears to light up. This was taken with the truck in the garage so the headlights were on at the time.It lights up? I never noticed, I have that control on mine but it's basically hidden behind the steering wheel so I've never seen it at night.
Howdy Gabe! Do you happen to have the file that you could share with me? I do have a friend with a 3D printer. Thanks!If you have or know anyone that has a 3D printer you could print out the part the way you want it. My buddy 3D printed the part for me and I put switches for my fog lights and ditch lights in it View attachment 430108
