21 - 23 of 23 Posts
The power goes out a lot around here too. I carry 4 - 6gallon cans in the back of the bed and use a ratchet strap thru the handles to the rear tie downs. Works great and nothing to fabricate.
when i need to get fuel i take two 5 gallon tanks, put them in the middle of the bed by the tailgate side, run a ratchet strap through the top handles across the bed, and tighten just enough.
Also, when the tanks are full, i screw the nozzles on and point them up, to avoid splls.
2021 Colorado LT, Extended Cab, Long Box, V6 4WD, Bright Blue Metallic
Discussion Starter #23
Thank you all for your great ideas. Since I’ll only be going between the house and the gas station with the cans (and if I have to, I have a cable lock I can secure them with) I chose the method with the cargo bar and the tie down strap.
Thank you again!
21 - 23 of 23 Posts
