1 - 7 of 7 Posts
I was wondering if anyone else was having this problem or if my truck has a defect. I have a 2008 Colorado Extended cab and I live In Washington state so it rains about every day. The problem is that in both corners in the very rear of the cab the carpet is always very damp and it gives the truck a moldly smell. Drying it and a little Fabreez takes care of that, but two days later the carpet is wet again. Any sugestions?
its the third brake light! i have an 04 and have the same problem. i had silicone run around it and it still leaks, so i just live with it.
third brake light, silicone worked for me. Take it off and silicone the crap out of it, but make sure you don't get it all around the outside on the truck
my 3td brake light was leaking too. I ended up pulling out the carpet & head liner to make sure it was completely dry - then I siliconed the 3rd brakelight.
mine was siliconed inside and outside the light, i may run another bead around it!
1 - 7 of 7 Posts
