What affect fuel mileage more, weight or diameter? Would a 32 inch tire that weighs 38 pounds be more fuel efficient than a 31.1 tire that weighs 42 pounds?
The change in diameter will increase your final drive ratio (numerically) by a very small amount, which will increase your RPM's at a given speed by a very small amount. How that effects your mileage depends on your driving habits. My sweet spot is about 65-70 for mileage. If I drive the mountain back roads a lot where speeds are lower than that, then a smaller tire would put me in the sweet spot more often. Which would, theoretically, increase gas mileage. Sounds good on paper anyway. But I would think the difference between those two sizes would be negligible.
A heavier tire usually decreases mileage because it requires more energy to get it moving, and more energy to keep it moving. 16 pounds of rotational weight is a lot. Especially in a 4 cylinder gas engine at high altitude. Maybe not so much in a diesel.
That much rotational weight will also effect braking.
All else being equal, I'd pick the lighter tire.
Good choice! In this instance I think you'll get better fuel economy with the 255/75/17 due to a narrower wind profile, less weight and less gearing (lower cruising RPM). The reduced width will play an even larger role if you plan on removing the air dam.Yes, thank you. I’m looking at Cooper At3 in either a 265 70 17 or a 255 75 17. 41 pounds vs 38. Just not sure if the 32 inch tire will cause rubbing issues with just a 2 inch lift.
Put yourself in OUR shoes....... Again, you’re splitting hairs. You’re asking about upgrades that are going to change / ruin your current gas mileage. Yet - you are asking how to ‘save’ gas mileage. What’s more important to you? Looks / Lift or gas mileage?Janster, I appreciate the assumption that I can’t afford the fuel for my diesel or that maybe I should just buy a Prius instead of trying to make rational decisions based on getting information from my fellow forum members. Damn, what was I thinking. It’s almost as if your channeling 08Canyon today.
