For experimental purposes, try a mid grade tank of fuel. Run tank almost empty and try a higher octane. It's worth a shot.
For experimental purposes, try a mid grade tank of fuel. Run tank almost empty and try a higher octane. It's worth a shot.I have an 2006 Colorado with a 3.5 liter engine. It has 110k miles. Last year I started hearing a knock coming from the front of the engine. It has gotten a bit worse over the last 6 months. The sound is present with or without the serpentine belt attached. The knock frequency is half the engine RPM at all speeds, cold or hot. You can have a listen to the sound at idle via the attached link.
New Recording 6.m4a
A friend is in the midst of pulling the timing chain but so far has not found any obvious problem. Any ideas?
Thank you RJL1983. If we don't find anything after pulling the timing chain, I will definitely try your "experiment". I appreciate the suggestion.For experimental purposes, try a mid grade tank of fuel. Run tank almost empty and try a higher octane. It's worth a shot.
I'm sorry to say but that sounds like a rod knock.Thank you RJL1983. If we don't find anything after pulling the timing chain, I will definitely try your "experiment". I appreciate the suggestion.
Thank you White016. I neglected to mention that one of my diagnostic tests was to disconnect the plug wires in sequence. The noise remained after pulling each of the wires.I'm sorry to say but that sounds like a rod knock.
good, usually a rod knock will change with load.Thank you White016. I neglected to mention that one of my diagnostic tests was to disconnect the plug wires in sequence. The noise remained after pulling each of the wires.
It's worth a shot at the leastI'm sorry to say but that sounds like a rod knock.
Since we have taken the pan off to get at the timing chain I will be sure to inspect the rod bearingsIt's worth a shot at the least
The sound is definitely coming from the front.Since we have taken the pan off to get at the timing chain I will be sure to inspect the rod bearings
