1 - 10 of 10 Posts
I would like to upgrade the horn. I used to have a train horn with compressor. I loved that thing but the compressor was bulky and loud. Looking for something as plug and play as possible. Thanks guys!
Summit Racing has a variety of horns available. Installation is fairly easy, you'll need to run high amp line from near the battery and a relay from the horn wire. Simple and inexpensive.
I installed this one. It's pretty loud. But I don't like it because it's kind of high pitched. It sounds european, not like an american truck should sound.
I found an unlocked '17 Ram pickup on a dealer lot and tried the horn and it was amazing. Way better than my '15 Ram so they must have changed them. Check those facts carefully though before you buy.
I'm going to mount some of these on the roof and do the same slick plumbing setup.
Reactions: Matt At
i bought a set of hadley bully air horns for under the hood, if anyone has a set, any ideas as to where to mount the tank and compressor would be appreciated. i checked youtube and one guy mounted the whole setup on the frame rail,(F-350) but seeing as tho the frame is boxed, and i live in new york(snow) not fond of installing them that way. the only thing i am sure of is i will be mounting the horns in the grill. again any ideas would be greatly appreciated.
I gotta laugh...
I've got some similar to these
Sounded like I stepped on my drive shaft... :surprise:
I wired back the stock to use in conjunction with these and it sounds more like a man again, sort of
after seeing what it takes just to get behind the grill on these trucks(way too much work!)i might put a backrack on mine and mount the horns there, or send them back and forget about it, I dont like the hella horns(they sound kinda cheesy)
1 - 10 of 10 Posts
