Touch-free car wash with undercarriage wash and rust inhibitor won't scratch your paint.What's everyone using to remove road salt from the undercarriage? I'm not really interested in bringing it to a car wash , I'd like to keep my paint scratch free. I'm thinking a lawn sprinkler?
Sounds like you're addressing removing mud more than salt. I would agree a higher pressure would be needed for that. For salt I would think volume of water would be the bigger factor.To do a decent job, you need high pressure. Driving over a lawn sprinkler really isn't going to get it.
You can buy an attachment for your pressure washer that will do the job. Do a Bing search on "undercarriage wash" for a variety of choices.
I usually drive through the no-touch car wash and pay for the undercarriage wash. It costs $2, but it gets a majority of the mud and road slime off. We don't use salt around here.
At a minimum you would need to keep the hose in a warmer space so that ice wouldn't block the flow of water. And you'd also need to worry about creating an ice rink wherever you did the rinsing!Around here, when the roads are salty my hoses are drained and put away for the winter.
No, I'm talking about salt. Mud just needs water, and preferably under pressure. Remember, all that crud under there isn't just salt. It's dirt, mud, oil, and other road crud. To get that off there you need pressure. A good solvent like Simple Green wouldn't hurt, either.Sounds like you're addressing removing mud more than salt. I would agree a higher pressure would be needed for that. For salt I would think volume of water would be the bigger factor.
GM does put some coatings on the frame. Exactly what is hard to say. Some form of sealant and waxy substances.No, I'm talking about salt. Mud just needs water, and preferably under pressure. Remember, all that crud under there isn't just salt. It's dirt, mud, oil, and other road crud. To get that off there you need pressure. A good solvent like Simple Green wouldn't hurt, either.
I moved here to CO from upstate NY about 25 years ago.
Crawled under your own twin yet? I don't know about you, but my Canyon's frame has no such waxy substance(s). The frame has been dipped in an e-coat or paint-like sealant, I can wash it with as much pressure and cleaner as I want and it's not coming off.GM does put some coatings on the frame. Exactly what is hard to say. Some form of sealant and waxy substances.
Pressure washing and simple green will remove those coats pretty quickly. As for how bad that is for rust I don’t know.
Yes. It’s there when new. It’s not very thick.Crawled under your own twin yet? I don't know about you, but my Canyon's frame has no such waxy substance(s). The frame has been dipped in an e-coat or paint-like sealant, I can wash it with as much pressure and cleaner as I want and it's not coming off.
I've owned my truck since it had 8 miles on it and have done all but one oil change so I've been under my truck who knows how many times since new, can't say mine ever had such a substance. I know what the rust preventative looks like, it's quite sticky and gooey. Can't tell you how many German cars I've seen "leaking" it in the summer or how difficult it actually is to clean off. My truck frame never had the stuff or if it did it washed off very quickly and was likely for protection during rail car transport which is Hell on paint and untreated metal. If it were meant to be a long term rust prohibitor they wouldn't use a thin coat that washes off just by driving in the rain.Yes. It’s there when new. It’s not very thick.
X2 for woolwax coating.Wool wax once a year. Sand (important) and touch up and paint chips once a year.
I never wash my vehicle in winter. No rust here.
That is realistically not true. You can stop the oxidation reduction reaction by lowering the temp enough. But, unless your garage is on Europa, it's not cold enough.I frozen salt caked truck won't rust if kept cold.
It's a 'kinda both right' situation. Salt can cause rust to form just using the humidity in the air. This is especially true with magnesium salts that are more commonly used with brining these days. With brine you have very tiny crystals (because they were dissolved in water) than can get all up everywhere and make a fine dust, which really loves to form rust just via some humidity.That is realistically not true. You can stop the oxidation reduction reaction by lowering the temp enough. But, unless your garage is on Europa, it's not cold enough.![]()
