I think mine is stopped up. No water on ground after running AC and parking. Smelly when starting AC. Is their a simple way to check on this?
The mfg's are locating drains to drain onto/close to the hot exhaust and vaporize, so puddles may not be visible all the time.Are you saying it's not suppose to leak water on the ground like all other cars I've ever had? I do have the 4 cyl.
Good idea. New to me. Thanks.The mfg's are locating drains to drain onto/close to the hot exhaust and vaporize, so puddles may not be visible all the time.
Have you changed your Cabin Air Filter?I have a 2015 Colorado and the AC smells like mildew when I have it on. I’ve tried to find the drain tube for it but haven’t had any luck. Does anyone have a picture or know of a video that could show me?
The drain hose is part 25I’ve changed the cabin air filter and it still has the smell. I bought some cleaner that you spray on to the evap core and it will clean and kill anything that might be growing on it. The easiest way of getting the cleaner on the evap core is going through the drain tube, the only other way is by taking the blower motor out.
Did this reduce the musty smell?I turned on the afterblow on my truck. I have access to a GM MDI Tool. Very easy to do.
