On the fence here. I think I've read every thread on the subject, but thought I would start my own. Since I got bigger tires, I really just want to fix my speedometer/odometer, but also wanted to see what the options were.
Rough Country Inline Speedometer Calibrator
- this technically doesn't ship to California
- does the truck adjust the shift points and RPMs to the corrected speed information? Or is all of that still mechanical gearing?
Here is information I've gathered from personal experience with my truck and exposure with a friends truck, a lengthy conversation with my local tire (DT) store manager and this forum:
Tire sizes can vary within a manufacture
on a specific tire.
The twins have (what is considered by those I have spoken with) a sensitive Traction Control System.
The Rough Country (RC) inline speedometer calibrator worked perfectly on my truck when I up-sized tires from OEM 265/65 17 to 265/70 17.
By worked perfectly is meant: noticed the change in RPM at given speeds were back to what they had been with OEM tire size, and shift points were back to what they had been with the OEM tires.
When I setup the RC spedo calibrator I input the specific size rather than what I have come to realize is the generic value. Generic Value example: 265/70 R17 / Specific Value example: 31.65 / 17
Also what is meant by worked perfectly: can set the cruse control to any speed value and it holds and performs as it should, traction control works in slippery conditions, all off-road settings work.
A friend has a 2020 Bison - he went directly from OEM size tires to KM3 35" and used the RC speedometer calibrator. Same experience that I had above - worked as advertised, cruse control, shift points, etc. I have driven his truck about half dozen times.
He recently re-geared to 4:10's and went with Duramax Tuner engine and transmission tune. He removed the RC inline speedometer calibrator. The shop that did the tune had to work with his truck a few times to get the calibration performing correctly for the speedometer (including using a GPS speed monitor). This shop is one of the sources for the Traction Control being sensitive. I have driven his truck a few times since (even as recent as last week) and it is performing extremely well - I am confident his speedometer is correct.
I also read the post on here questioning that the speedometer correction is not correcting the odometer. After a period of consideration and cross referencing what I have observed (not perfectly scientific) I am of the point of view that the speedometer correction also corrects the odometer. Until sufficient evidence is discovered that the odometer is not corrected I maintain the point of view that it is.
I suspect that with a re-gear and change in tire size that more than the inline calibration is needed.
