Hey guys. Has anyone used the Trigger 4 wireless controller. I’m just trying to get my head wrapped around the wiring of it. I have a Rigid auxiliary high beam light bar on my 22. It’s not wired yet and I came across the Trigger setup. My rigid harness has two relays in line, the positive and negative connections and then 5 wires I believe that run to the switch. It looks like with the trigger set up you just connect the positive and negative to the system. I could be wrong though. Does the trigger system have built in relays? Any info on how the harness connects would be greatly appreciated. Thanks I’m advance.
