I purchased a Jayco Jay Flight SLX 265RLSW Travel Trailer and thought I would share some real world towing experience with my Duramax Colorado Pickup. The camper is 26 ft with a overall length of 29 ft tip to stern. Although all the numbers indicated this combination would work, I loaded up camping supplies, food, and tools in the camper and headed for the scales to get actual numbers. All the weights were below the weight ratings with the closest being the trucks GVWR which was expected. With me, the wife and dog along with the tongue weight we are close but still 215 lbs under the 6000 GVWR of the truck. 85% of GCWR with 13% tongue weight. The trailer weighs 6300 lbs loaded with a 7500 lbs GVWR. The combined weight at the scales was 10,860 Lbs, that is without the wife and dog.
The trucks integrated brake controller, diesel exhaust brake and trailer sway control software along with the four point equal-i-zer weight distribution hitch keeps everything in check. The Duramax Diesel pulled fine with plenty of power and stopping was not an issue. I certainly know the trailer is back there but I did not feel unsafe. Trailer tires are rated at 65 mph so I never went above that. 60 to 65 mph was comfortable. When passed by 18 wheelers you will feel a wiggle but the trailer quickly lines back up. Guess if you want a tow vehicle that won’t feel any wiggle at all would require a 1 ton dually which weighs way more than the trailer and even then the trailer will still probably wiggle when passed by a big rig or you get a strong gust of wind. Close friend with pretty much the same trailer but 29ft is towing with a F250 and no weight distribution hitch and he is really complaining about the wiggle when being passed by big rigs.
I added the clip on trailer mirrors. I don’t see how anyone could tow a 8ft wide camper without modifying our stock mirrors one way or another. Pretty flat in Florida with only a few steep hills also known as bridges and we do have many of those in the Jacksonville area; Duramax pulls them without an issue. If I were to rate the truck in power, stopping and trailer stability I would say no problem with power at all, braking next but really no problem if you follow the set up procedure for adjusting the brake controller, last would be stability. You will know it is back there and will get some wiggle from time to time. The first few times you feel this is unnerving but after you have towed a few hundred miles and become more comfortable that it will line back up you build confidence in the combination. If you are considering towing close to the trucks capability, get a good weight distribution hitch, change out or add on trailer mirrors and lastly travel at a reasonable speed. I feel safe towing this trailer with our trucks and believe the 3/4 ton truck pulling the 20ft camper at 80 mph weaving through traffic thinking their invincible is at much greater risk of catastrophe than any of us towing below all of the weight ratings at a reasonable speed.
