1 - 20 of 32 Posts
Hi, I have a 2018 Colorado and sporadically upon start up, I get a weird clunk in the vicinity of the transmission. It doesnt do it all the time and I cannot say what makes it do it or now do it.
Of course, I have taken it in to the dealer twice and they cant find anything.
Has anyone had any kind of issues like that? Thanks!
Super Moderator
It is the Cold Start up Hard Shift 1-2 2-1. Once your transmission fluid warms up it usually goes away.
Reactions: Firehk
I read OP as saying that while in park and while starting truck OP hears a sound?
Is your truck in 4A or 2H ?
Brand new 2021 does it and was told it is normal, they couldn’t give me an exact point of what causes it. The closest I could tell is that on my vehicle it is either the rear diff or the tranny….pita to have someone start it after it sits for at least an hour and lay under the truck to see what happens….I gave up and consider it normal in my circumstance, after all it was new.
It is like the clunk during a slow sharp turn over a bump…..they tell me its normal.
Discussion Starter · #17 ·
Ugh. The "it's normal" is not normal. This doesn't happen to most other vehicles. Thank you.
sounds like the torque converter is draining down as others have noted on here. Start it up and fluid goes back into the torque converter while still in park and causing the clunk...
If it’s safe and too expensive to remedy….i guess it’s normal. Probably too much a fight to get the contractor who machined the parts for the contractor who made that part for another part for the contractor who supplys GM the trannys.
Part of the problem is you were not very good at describing what was happening. People were assuming other scenarios.
If it's happening before you switch out of park I suspect it's not transmission or drivetrain related, but no guesses.
1 - 20 of 32 Posts
