1 - 8 of 8 Posts
Hi All,
This past weekend I took my 2016 LT (gas V6) for a ride through the mountains of West Virginia. On some of the long downhill glides (5-6% decline for a couple of miles) the transmission seemed to have a mind of its own. It would shift into a low gear, RPMs would jump to 5,000 or so and the engine and transmission sounded like they were going to explode. The transmission wouldn't up-shift, and the only solution I found was to put it into neutral until we hit the bottom of the slope. If I went from neutral back into drive, the transmission was still in a low gear.
I didn't play with the manual option as I had never used it before and figured this wasn't a good time to try to learn it.
Has anyone seen a similar behavior before? Is this normal? If not, any fixes? I'm not sure how to explain this to the dealer in such a way that they won't just say "no codes, all is good." Should I just use the manual mode when on a long downgrade?
I haven't reread my manual in years, but I seem to remember an engine braking feature to our trucks. Not many real hills in our city, but I do know what you are talking about.
Reactions: imref
Only ways I know to disengage -Apply light throttle, shift to manual, hold tow/haul button for about 3-5 seconds
I should have searched more thoroughly. You are correct, it’s a feature:
2020 Chevrolet Colorado Crew Cab Short Box LT
I use L gears on steep grades and when mountain roads are slick to prevent unwanted shifting. Mostly a result of driving a manual transmission most of my adult life.
I have not downshifted into L over 70 mph. At 70 L6 seems to have two gears. When climbing in L6 I'll notice a change in power and RPM's when the grade changes.
Hi All,
My 2016 V6 has never done this, with or without a trailer behind it. It will seem to hold a gear but not a gear at 5000 RPM! Strange I think. I've gone down the Grapevine in Ca many times and I believe it's right at 6%.
All that I can think of is you need to slow down.
My 2018 V6 has gone as high as 5,000 RPM with the Grade Braking (at 11,000 lbs GVW down a long grade in Colorado at maybe 65 mph). Surprised, but even at closed throttle sustained 5,000 rpm is not going to hurt this engine.
Just don't tell my wife... to her, I'm always wrong with no memory... :)
We have one good inclined road here, and I know I can just stay of the gas and the truck will just cruise down without gaining any speed, never paid attention to my rpm though.
1 - 8 of 8 Posts
