1 - 5 of 5 Posts
I noticed my transmission will suddenly go out of lock up while I am on a flat roadway, steady throttle and steady 60 mph. The change is felt as a slight drivetrain thump while I am driving. The rpm's raise and lower dramtically
when I move throtttle. After about a minute, the transmission will suddenly return to full lockup. It's done this several times now. Is there anyone else that has this problem? Are there any TSB's out there? I just wanted to know if this was a serious issue before I take it to a dealer. BTW, no check engine lights noted when this stuff happens.
I am from Canada and was checking to see if anyone had this problem of
the torque convertor unlocking for no reason. I am glad to see that I am not krazzy like the DSM from GM thinks.
My 2007 Canyon started to do this at 12,000km and I have had an uphill
battle with GM since and still do not have it fixed.
It does just what you have stated in your post.
Good Luck with this.
same here and i'm in canada also...gm keeps telling me they don't feel anything wrong
1 - 5 of 5 Posts
