Have anyone tried this towing combination on the highway, in order to cut down on the downshift/upshifts? Thanks for you input.
First off, in your sig line you say you have a 7,700 pound hitch, but recognize that you are only rated for 7k.Have anyone tried this towing combination on the highway, in order to cut down on the downshift/upshifts? Thanks for you input.
Just looked at the label on the hitch and states 7,700 lbs. Max. Tow vehicle may be rated less. I know it is rated at 7,000 lbs.First off, in your sig line you say you have a 7,700 pound hitch, but recognize that you are only rated for 7k.
I am only towing ~3k when I tow usually. The one time I towed closer to 4500 pounds, I saw similar results. I don't feel like I am getting that many downshifts/upshifts. I never tow with cruise control, I let my foot control the shifting and float my speed to try to minimize the shifting. It does seem in Tow/Haul mode I fight the shifting a bit less still.
I know most of Texas is pretty flat, but East Texas has some pretty good hills.
I wouldn't do it cuz I know limiting myself to 4th gear for my typical tow would hurt my gas mileage. Two weeks ago towing my popup out to the State Park and back, I know I saw 6th gear at many points in the drive.
All of this might be different decision with a heavier load, perhaps in city driving.
I Tow a lot in East Texas and even in M5 with Tow/Haul, it still constantly shifts up/down on the hills. That really changes the Trans. Temps.
What are you towing? A small utility trailer, that is awful. A large travel trailer at 6000 pounds and lots of air resistance, not so bad.I only get about 11.5-13.5 in M5 with Tow/Haul. It was about 14.5 when the truck was new. Only about 8,000 miles on the truck now.
