lmfao!the front "mud flaps" are technically called a wheel spat. They are there for aerodynamics, not sure if they add any protection to the truck, but i guess if you do most of your offroading in reverse, they might help.![]()
^^^ThisThe front "mud flaps" are technically called a WHEEL SPAT. They are there for aerodynamics, not sure if they add any protection to the truck, but I guess if you do most of your offroading in reverse, they might help.>![]()
Sorry didn't read the post clearly enough...I thought he was referring to the small mud flaps behind the front tires...The front "mud flaps" are technically called a WHEEL SPAT. They are there for aerodynamics, not sure if they add any protection to the truck, but I guess if you do most of your offroading in reverse, they might help.>![]()
