I have a question that when searching the forum I couldn’t find a clear answer to. When you unlock the door using the key and not the fob the horn starts to honk as part of the theft deterent system until you put the key in the ignition. If you fail to put it in the ignition within several seconds the alarm goes off. How does one go about disabling this feature? I can’t seem to find a configuration setting or control. If that is not possible then I welcome whatever physical bypass suggestions you all can come up with - even if it is as severe as yanking out the alarm system altogether.
Now before you reply with a “why don’t you just use the fob” question let me explain why this is a big deal for me. The nature of my work requires me to travel to secure facilities. Some of these facilities have electronic suppression and RF interference control systems. These security controls may interfere with or jam RFID based devices. So depending on which facility I’m at that day my fob may not work properly forcing me to rely on the physical key.
