Taillight and CHMSL Incandescent Bulbs - photos with bulb numbers
1324 Views 19 Replies 10 Participants Last post by  _Montana_
6
I noticed that the tail light backup lights and bedlight had the typical yellow tint of incandescent bulbs. The Owners Manual did not have any bulb info, so I decided to investigate. The stop light in the taillight housing is also incandescent, as are all three of the bulbs in the CHMSL (Center High Mount Stop Light). I do not plan on replacing the brake lights bulbs with LEDs because of all of the trouble I had with burning out LED resistors on my 2018 Canyon. I eventual put the incandescent bulbs back in on that truck. The screws for both the taillight housing and CHMSL are T20.
I also noticed that stamped inside the hole the CHMSL fits in are the words "CREW". I wonder if there are plans to add different CAB types and possible a long bed down the road.
Photo 2 is the backup bulb (gold lettering)
Photo 3 is the brake light bulb
Photo 6 is the bulb in the CHMSL (all three are the same)
I hope you find this information useful.
Bill
See less See more
Reactions: 4
1 - 20 of 20 Posts
Did you do the brake lights in the taillight housings, and if so, did you have to add resistors?
Bill
Bill
No I didn’t. I didn’t want to go that far yet with resistors etc. I will do it if someone finds a bulb that doesn’t hyperflash
I noticed that the tail light backup lights and bedlight had the typical yellow tint of incandescent bulbs. The Owners Manual did not have any bulb info, so I decided to investigate. The stop light in the taillight housing is also incandescent, as are all three of the bulbs in the CHMSL (Center High Mount Stop Light). I do not plan on replacing the brake lights bulbs with LEDs because of all of the trouble I had with burning out LED resistors on my 2018 Canyon. I eventual put the incandescent bulbs back in on that truck. The screws for both the taillight housing and CHMSL are T20. I also noticed that stamped inside the hole the CHMSL fits in are the words "CREW". I wonder if there are plans to add different CAB types and possible a long bed down the road. Photo 2 is the backup bulb (gold lettering) Photo 3 is the brake light bulb Photo 6 is the bulb in the CHMSL (all three are the same) I hope you find this information useful. Bill View attachment 447158 View attachment 447154 View attachment 447155 View attachment 447159 View attachment 447157 View attachment 447156
Could these all be replaced with: T15 912 921 906 W16 of similar shape found on Amazon? https://www.amazon.ca/AUXITO-Lumens...r+3030+xenon+white+6000k+1550+,aps,155&sr=8-3
Bill
It uses the same High Mount Brake Light as the 2nd Gen:
Cab Structure is the same
High Mount Stop Lamp - GM (52127100)
2015-2022 GM
2015-2022 GM High Mount Stop Lamp 52127100 | GM Parts Online
Does not Matter Crew Cab or Extended Cab
Does not matter 5.2' or 6.2' Bed
Your Picture... Part number on it:
See less See more
Reactions: 1
2015-2022 GM
Good information. Thanks for pointing that out.
Bill
Reactions: 1
I have a good story about LED resistors. :p
When I got my Jeep I replaced my taillight bulbs with LEDs, they had the inline resistors built into heatsinks, and came with double stick tape to mount the resistor so it wasn't just bouncing around.
Well, they apparently got much hotter than anticipated, came loose from the tape and came to rest on the lens of the taillight, and eventually melted a good portion of if. :)
Ended up just replacing the entire taillight with a nice sequential LED set.
  • Wow
Reactions: 1
On my 2018 Canyon I used double sticky back tape to secure the resistors on the GEN5DIY harness thinking that they just get warm. I ended up using 14 gauge wire to secure them to holes in the sheet metal. After being told by GEN5DIY that the resistors were wear items and replacing them 3X, I went back to the incandescent bulbs for the taillights and turn signals.
Bill
Doesn't the build site specify "LED tail lamps"?
I know it does on the Z71 and ZR2.
I thought that was the case, too. It does say Exterior LED lights, but obviously not all of them. I think everything but the CHSML, taillights, brake lights, backup lights are LEDs. The rear DRL in the taillight housing is an LED pipe. I really doubt the ZR2 would be any different than the rest of the trucks.
Bill
Bill
That's what I was wondering. I was curious why they would say rear LED's and not have any, but it's just the "DRL" they have back there. I really want to see these tail lights at night. I know yours are different on the GMC but I'm curious what they look like with the DRL's on, turns on, and what the brake lights look like when illuminated.
I have yet to come across a single LED bulb on my Trail Boss and so far I have changed the interior, headlights, cab and reverse light bulbs. Not touching any turn signal or brake bulbs until I see a bulb that does not cause hyperfash issues without adding a resistor
The Canyons have an LED pipe around the taillight. You can see the cable for the LED that goes to the top of the housing in photo 1. I am not sure if the Colorados have an equivalent to that or not.
Are the headlights on the TBs reflector or projector?
Bill
I have bad news for ya
Anyone know the bulb type/size for the front signals on the new trucks?
turn/Park are 7444NA-M
Technically it does have a rear LED but it's just the tail light the brake and signal are not.
If you ever get behind a Sierra Elevation at night it's the same idea, LED tail light and incandescent bulb. To me it looks cheap.
Reactions: 2
2
Totally agree. Feels like them even putting "LED" in the description is manipulative. I love the idea of being able to replace the bulbs myself, so kudos to them for doing that, but labeling the whole things as LED's and still using incandescent bulbs is a cheapo deception move.
I don't understand why it's so hard? We want LED's to simplify, last longer, and be brighter. Instead, we are forced to get packages that would force you to replace an entire housing for gross amounts of money because nothing inside them is interchangeable. I can't even count how many new vehicles I see on the road daily that have one DRL working and the other not working. One - they probably don't even realize it and two - if they knew how much it cost to replace they probably wouldn't bother. Now factor that in for headlights and turns. I'm honestly not sure what's worse - getting the crappy bulbs and having to replace them, or getting the expensive housings and hoping they work.
When I got my Tacoma I was so happy about the headlights, only to learn they used the yellowest of yellow cheap bulbs literally everywhere else, including in the cab. Plus, they had the ugliest brake lights, I had to get the Meso kit for $150 after seeing other Tacoma's on the road and going "Wth is wrong with their taillights?" Here is the difference:
The stock brake lights were so ugly. And the sad part was that if you got the upgraded black version instead of the chrome ones, there is a whole portion that leaks through the sides and remains lit - the ones they use on the TRD Pro models. The headlights I love - but not interchangeable. If something goes out it's either aftermarket sequentials which are even more then OEM unless you go cheapo Amazon ones that will likely fog up and/or die again or OEM that are barely cheaper than some of the 3rd party sequential options. The "cheaper" ones on Amazon are still like $600, so why risk it? I'd rather be confident in what I'm buying than have to buy them 3 times.
On a 2023, with all the new features of the ZR2 - I expect better. Quality has not increased very much overall (The 2nd gens are very nice trucks and really the only feature they lack are ventilated seats and adaptive cruise) and we are still paying for safety packages that should be standard in all models now days - so why can't we have simple features like this? Feels like the shortages are less of a shortage and more of a carefully planned attack that is being drawn out to milk every penny from the consumer. Just saying...
It's things like this and the constant not so buggy more of a pure negligence and more a lack of QC on new vehicles (all around - not just first year models and certainly not limited to the twins production) that are making me reconsider this move all together. I saw it on both vehicles I bought in 2021 and never noticed anything like it before those years. If you label it as LED's - put LED's in it. If you put a 4 cylinder in it - make it more efficient than the last model. If your machines suck at painting - let a human do it. Otherwise, what is the point? Pay more for less? No thanks.
Even trying to remain optimistic is hard. You see one post on here with some random issue and it just drains you. Even something as simple as this - because they 100% are listing these tail lights as LED's. Things that should not happen in 2023, and I can't blame people for their attitudes when it happens to them or when this stuff gets exposed. It's stressful. So much of our lives rely on these vehicles now days and to some people, making that move is a jump into debt that may not have been the smartest - but if the quality was there at the very least, once it's over, you have a vehicle that has lasted and that in itself, is worth every penny to most people. Instead, most people plan to spend more money to make a new vehicle work for them and when it doesn't, you feel ripped off. Vehicles now days hold the same value as a house because of how reliant our society is on them, and also the mass amounts of people currently not able to afford housing so they turn vehicles into them!
Grr /rant
We want LED's that function properly in the proper housings and are user replaceable! Stop being cheap! The more I see, the more I feel like the whole thing isn't worth it.
See less See more
Reactions: 1
1 - 20 of 20 Posts
