Hello Colorado experts.
I have an 06 colorado extended cab. It was hit by a drunk driver in the spring on my from driver side, directly on the wheel. I have since had continuous electrical problems. I have a new alternator, new wiring to and from the alternator, a new battery, new radiator and fan, new ecm (I replaced this trying to troubleshoot the issues), new grill, side panel, new bumper, and new headlight assembly. The accident was significant enough to crack the alternator housing, so I imagine just about anything could be broken, and the insurance company was silly enough to try to fix it instead of replace it. I love my truck, so I don't mind.
Here are the problems, mind you it runs fine except for these issues:
1) I get a low battery light when at idol, or when I down shift too late headed up a steep hill on the highway. This is in the context of a new alternator and battery.
2) When I down shift at highway speeds for a steep hill, my airbag light goes on, I get an abs fault, by air conditioning stops, and my head lights turn off.
3) My camshaft sensor just went out this morning.
4) I did replace the ecm in August after I got a high voltage code. I haven't seen the code again, but thought it worth mentioning.
5) This maybe my bias, but I notice this happening more midday. I think its because I've been driving, the engine is hot, and its shorting out some wires as the wires heat up.
Oddly enough, my fuses are fine... one would think I would blow a fuse given all the electrical issues. Going to the dealership is not an option. I'm a student, so dropping 2K for going without a vehicle for a couple weeks is not an option. I need to fix this on my own.
I found some interesting youtube videos where people similar issues and fixing a ground short fixes the problems, but I don't know where to begin. There are so many things grounded on my truck.
Thoughts? Where do I start? Ideas?
