Strut install
790 Views 11 Replies 7 Participants Last post by  Allan28
Looking to change my shocks and struts on my 2018 4wd Colorado, and was curious if anyone knows for sure if the upper arm knuckle will need separated to allow for strut install?
Just looking I realize I will have to remove the sway bar, and thinking it might fit up in place without, separating the upper knuckle but wasn't sure. Just wanted to find out so I know what I'm getting into before doing it?, Thanks
1 - 12 of 12 Posts
  • Helpful
Reactions: 2
Go to YouTube & view @fondupot videos - he breaks it down...step - by - step. :D
  • Haha
Reactions: 2
In short, yes, you do have to disconnect the upper ball joint. Not a big deal, easy to do.
Fondupot videos are good and he's on these forums.
But yes, you will need to disconnect the upper control arm ball joint, sway bar, tie rod, and end links.
It is not difficult, but you must ensure you support the lower control arm to prevent the brake line or ABS sensor wire from holding up the entire assembly, as they can break/cause you issues.
PB blaster might be helpful, but the electrodeposition coating on these trucks is still going strong on my 2016, though I don't live in the snow belt.
See less See more
  • Helpful
Reactions: 1
So true
Have learned always found the videos done by @fondupot to be outstanding
Thanks for everyone's info, was thinking with complete removal of sway bar it might be possible, but I was wrong, from the replies. Knowing this I'll know what to find torques on beforehand, Thanks
Reactions: 1
3
This should be what you're looking for, however some are awkward to get to with a torque wrench and you may need to tighten until you feel confident.
Front Shock Absorber Upper Nuts (3x): 43 lb ft
Front Shock Absorber Lower Bracket Bolt: First pass: 74 lb ft, final pass 25-35*
Front Stabilizer Shaft Bolt: 37 lb ft
Front Stabilizer Shaft End Link Bolt: 22 lb ft
Steering Linkage Outer Tie Rod Nut: First pass: 26 lb ft, final pass 85-95*
Front Upper Control Arm Ball Stud Nut: First pass: 37 lb ft, final pass 90-110*
I recommend everyone re-torque or re-tighten suspension components after ~500mi, and then apply DYKEM Cross-Check torque check/seal for easy visual inspection.
See less See more
Thanks for torque specs., saves me some time since I don't have a maintenance manual, always used German torque specs. gutentight😁
  • Haha
Reactions: 1
Normally I am too, but suspension, brake, and engine components get torqued as accurately as I can haha.
@Allan28
Front struts can be done without disconnecting the balljoints from the knuckles on the upper and lower control arms. You only need to remove the sway bar end links and the sway bar, and disconnect the tie rod. But then there is plenty of room to remove the OEM strut and reinstall a new strut.
This video should lay it out for you
  • Helpful
Reactions: 2
Thanks Fondupot, appreciated, the last time I changed my oil, removing the drain plug and looked at the strut, I was thinking it might fit, but wasn't sure. Thanks
1 - 12 of 12 Posts
