I'm just curious.
I had my truck off of the ground yesterday and in 2WD mode. I noticed when I spin one wheel only THAT wheel spins and if I spin the driveshaft from the front differential to the transfer case only the shaft spins.
I have a car with an LSD and if I did this both wheels would spin the same direction and I know that with an open diff that they would spin the opposite direction.
What I found out is that when you put these truck into 4WD it locks the transfer case and locks something in the front differential.
What I want to know is why does it need to lock anything in the front differential if the truck has an open differential in the front?
I hope this makes sense.....
