You solved your own question. 🤷🏻♂️ Set toe as close to zero as possible, or ever so slightly toed in. Next time get a printout of your alignment readings too.
You solved your own question. 🤷🏻♂️ Set toe as close to zero as possible, or ever so slightly toed in. Next time get a printout of your alignment readings too.After I got my alignment, my 05 canyon started to squeal as if it was out of alignment. I checked the toe with toe plates and it had a toe out of 1in. This was over the span of 1 month and two alignments. I have installed re indexed torsion keys, 3in fabtech spindles, new Silverado inner tie rods, Moog outer tie rods, new steering rack. Any help would be greatly appreciated. Mahalo!
The alignment rack set my total toe to -0.01 but the truck would come out of alignment after having it zeroed. My question is why it’s doing this regardless of having everything else torqued to spec not why my tires are squealing.You solved your own question. 🤷🏻♂️ Set toe as close to zero as possible, or ever so slightly toed in. Next time get a printout of your alignment readings too.
I bet it is the alignment adjuster cams for the lower control arms. Just because it's torqued properly doesn't mean it can't move. They are sliding adjusters. Toyotas are notorious for having the same alignment cams move so much, it bends their retaining tabs. In our case those are pins, for them it's sheet metal tabs. I would recommend getting everything back into alignment. Before leaving the parking lot, mark all the adjuster cams with a paint marker to have a "zero" reference.The alignment rack set my total toe to -0.01 but the truck would come out of alignment after having it zeroed. My question is why it’s doing this regardless of having everything else torqued to spec not why my tires are squealing.
Jeez, 1" out! That's A LOT!After I got my alignment, my 05 canyon started to squeal as if it was out of alignment. I checked the toe with toe plates and it had a toe out of 1in. This was over the span of 1 month and two alignments. I have installed re indexed torsion keys, 3in fabtech spindles, new Silverado inner tie rods, Moog outer tie rods, new steering rack. Any help would be greatly appreciated. Mahalo!
