That goes right along with my motto: "when at first you do not succeed, use brute force"Mine did this from new. Then I let my girlfriend drive the truck and she didn’t see a huge speed bump in a neighborhood and nearly got the truck airborne. Somehow that realigned everything and the squeak has been gone for several thousand miles. I can’t condone this method though lol
Oh heck no, can she come drive mine >Mine did this from new. Then I let my girlfriend drive the truck and she didn’t see a huge speed bump in a neighborhood and nearly got the truck airborne. Somehow that realigned everything and the squeak has been gone for several thousand miles. I can’t condone this method though lol
Do you have a picture where I can look for this?I had this issue, turned out to be the emergency brake cable not sitting in the holder correctly. I zip tied it to the holder and the noise it gone. Sorry no pics - look at the drivers side, the cable will be obvious.
This is dead on. This started to drive me insane. I saw something about it on Youtube. A simple application of grease and life is quiet. Trying to spot deer on dirt roads got to be a challenge.:xI had this problem for 45K miles. Ended up that the rear brakes needed brake grease. The guides and contact point on the pads needed a little grease and the annoying chirp of every bump went away. The dealer tried to find the issue twice. The final clue was that the squeak was worst when applying sight pressure to the breaks. Give it a try. It was a 45 min fix and virtually no cost.
Thank you for this good sir!I had this problem for 45K miles. Ended up that the rear brakes needed brake grease. The guides and contact point on the pads needed a little grease and the annoying chirp of every bump went away. The dealer tried to find the issue twice. The final clue was that the squeak was worst when applying sight pressure to the breaks. Give it a try. It was a 45 min fix and virtually no cost.
