1 - 8 of 8 Posts
I was able to get a deal on a sport bar for my truck, only thing is that it didn't come with the brackets. I'm having trouble finding replacements, does anyone have a solution for this or where I can buy those brackets. Part No. etc. ? Any help would be greatly appreciated. Thank you
379497
2018 ZR2 3.6L
Reactions: monteholic
Unfortunately GM no longer sells the bracket kit assembly. The manufacture only distributes the entire set together. I am screwed right now. Fabricating a clamp is my next step, but that is going to be a challenge in itself.
ANYBODY ELSE WITH ADVISE?
I need new brackets too. I have a set but they are cheap cheap metal, and after we removed it from the truck it originally came on, the holes are ovaled out badly. I'm going to install them again, but if someone has a resource without buying the whole bar, it would be amazingly helpful!
I drilled the sports bar directly into the truck. Took 10 minutes. I bought premium stainless steel hardware and it is holding up well. You would never know
Here is the part breakout from the GM Electronic Parts Catalog,
If you are looking for the underbrace, i.e. Part # 16, that is part of a Kit K02 which includes parts #10, 11, 12, 14, 15, 16, 17, 18, 19, 20, 21 and the Kit part# is 23325907 and the List Price on that kit is $235.00, but a simple google search and you should be able to find it cheaper for around $150.00.
Good luck
1 - 8 of 8 Posts
