1 - 13 of 13 Posts
I'm trading in my 2019 ZR2 diesel so I'm selling a set of low and high beam Morimoto 2 stroke 3.0 with the anti flicker harness for the low beam set and cap extension for a Chevy ZR2.
I purchased these LEDs bulbs on January 27th 2021 and it toke a month to get them.
CORRECTION: I purchased them on December 28th, 2020, however due to missing items such as the cap extensions, the back-ordered low beam bulbs and that I realized I needed the anti flicker harness. Both set ended up being installed in early February of 2021.
These bulbs are fantastic but expensive, I paid over $400 for the two sets. I think they are now $450.
IMHO well worth the money, makes a huge difference.
I'll take $300 + shipping OBO
I'll provide the proof of purchase so you can enjoy the three year warranty that goes along with the bulbs. .
I will confirm this is an awesome upgrade for. These w stroke 3.0s make the stock projector work very well.
These are the low beam bulb set with the anti flicker:
($244..00)
These are the high bean set:
($195.00)
$300.00 for these lights is a deal, I promise you that you won't be disappointed.
Definitely interested any before and after pics? Any picks of the cap extensions? Assuming you installed them, did you get flashed with them, any oncoming driver feedback?
I originally purchased two sets of cap extensions, but only used one set for the low bean. There's was no need for them in the hi-bean, since the bulbs fit fine without them.
So these extension caps are new, I tried looking for the bill to check the price didn't find it. But it wasn't expensive, I think something around $12 for the pair.
They are rubber, you'll need 2 1/4" hole saw/drill. when you drill out the cap you must favor towards the 12 o'clock position, because the back of the bulb is not centered to the cap.
Yes: the low beam bulbs were installed for about a month and half, while the hi-beams were on for three weeks.
I don't have before and after photos, but they were amazing compared to the factory and better than the previous set of LEDs that are mentioned a lot in this forum. (DD)
I will ship them in the original packaging.
Thanks, I’ll PM you a little later, running out for the day
While i was doing a little more research trying answer your cap question I realized I was mistaken on time frame and I want to make sure I correct my mistake:
Ordered both sets on December 28th.
Received a B/O notification for the hi-beams on the 29th.
Received the low-beams on January 6th 2021
I realized they didn't fit and that they flickered. So I removed them and ordered the anti flicker, and the cap extensions. I received the anti flicker on January 23rd and don't recall the exact date the caps came in, but I did install them at the same time. So the Low beams were installed in late January or early February.
I received the back/ordered hi-beams early February (2nd). so in all honestly I was wrong they have both been installed within a week or two of each-other.
So in all likelyhood they have been on the truck for just under 2 months.
I have the same bulbs. They're quality. I am only running the low beams. They did not flicker in my truck at all. Also, the DRL dimming function does not work on my truck.
Discussion Starter #10
There's a dramatic difference when these bulbs are installed.
There's folks out there removing the whole headlight to swap out the projectors. I thought about going in that direction, however after installing these bulbs I feel they eliminate the need to do any of that. Furthermore it's a simple install and the improvement is outstanding, it saved me all that work in a projector swap and the expense.
Pleasant transaction, and great communication. Everything you want from a seller on these forums. Thanks for the deal on some great lights =D
Discussion Starter #13
Thanks!!
Hope you enjoy them as much as I have. I think they're a great upgrade.
1 - 13 of 13 Posts
