Currently have my truck in 2wd mode. When the white stuff falls, should I throw it in auto mode?
When does one make a move over to 4WD low and high?
There is no need to limit your speed in 4hi. I mean unless conditions warrant, but 4hi goes to the governed vehicle top speed.Here is how I use the 4 wheel drive system in my Z71.
2wd - normal, dry road conditions, any speeds
AUTO - rain or light snow, wet roads. any speeds (flip on the fly when needed aka, taking off straight and turning from a standstill.
4hi - heavy snow or off road, limit top speeds to around 35-40 mph. If you are in 4hi, conditions should reflect a slower driving pattern.
4lo - LOW Speeds, heavy snow or off road. Emphasized LOW speeds. You should not drive in this mode on public roads.
I put a few sand bags in the bed as well. I framed them between the wheel wells with some lumber. It comes in around 290 pounds. I've never not done it. Anyone else find traction to be different with 4-wheel and no weight?Here is how I use the 4 wheel drive system in my Z71.
Technically yes, you can engage 4hi at any speed, but I wouldn't advise it.There is no need to limit your speed in 4hi. I mean unless conditions warrant, but 4hi goes to the governed vehicle top speed
Not a terrible idea, but I have not done if for about 10 years. Definitely helps with extra traction. I just don't like adding the extra weight and losing the cargo space.I put a few sand bags in the bed as well. I framed them between the wheel wells with some lumber. It comes in around 290 pounds. I've never not done it. Anyone else find traction to be different with 4-wheel and no weight?
I agree for the most part. If there's more than a dusting of snow I will probably go into 4hi to ensure all 4 wheels are getting power.Here is how I use the 4 wheel drive system in my Z71.
2 wheel until I can’t move. Then 4 hi. I don’t like the computer deciding where my power goes. It may work great in auto, but it’s all personal preference. You can run 4 hi at any speed, just make sure you engage at a lower speed. If there’s sections of bare or wet pavement, I’d go back to 2 wheel or auto if you like that. If you’re not experienced or confident enough to drive near the posted speed on snow covered roads (with good visibility), please put your flashers on and let people pass if you start causing a parade. If it’s really bad visibility, don’t go out. If you must, flashers, lights turned on via switch (sometimes auto lights think lots of white snow is daylight and will only trigger DRLs), and drive slowly. Don’t always rely on the tracks you’re following, you could be following them into the ditch or worse oncoming traffic.
And for off-road? 2hi at the rev limiter with the rear locked in offroad mode with the nannies off! Then switch to 4 dig when **** gets deep!
This! Voice of experience.
People using their lights on highways in snow is always a nice thing. ( Friggin Morons!). Just as @G2SKIER mentioned.
I'm in a Canyon but I have the same tires so.... I agree with this.Here is how I use the 4 wheel drive system in my Z71.
