1 - 17 of 17 Posts
I have a small tinny rattle coming from my drivers side mirror, It is very faint and pretty much nobody but the driver will hear it but its definitely there. I notice it pretty much anytime my driver window is down and is most noticeable driving around 15-30 mph over small bumpy road. It sounds like someone is tapping a needle on metal, has anyone encountered this? Ive taken the whole mirror apart and cant locate the exact area its coming from.
Yes, I had this. If you pull the mirror part off you’ll see a little metal tab on the left. It needs to be bent outwards slightly to put pressure on it and that will stop the rattle.
Is that where that rattle is coming from... it’s annoying and couldn’t figure out where it was.. thanks!!!!
Yup. It’ll still rattle with the mirror part removed, the housing puts pressure on the tab once you put it back in. I noticed the rattle the most when closing the door after getting out.
I took the whole mirror apart and drove with the mirror and rear housing off and it was still there...at least I thought so but I will try this and report back!
Well, it’s possible you have a different rattle but this was a metallic, coin-in-soda-can-like rattle and now it’s gone.
Thanks!! Had some time and bam.. fixed.. thanks again.. but now I find I hear another rattle coming from either under the dash or engine bay.. it seems like it only happens when it’s cold or on bumpy roads.. sounds like a click.. any ideas? Thanks again!!
Theres a thread for that - http://coloradofans.com/forums/226-diesel/308842-low-rpm-rattle-firewall-fixed.html
http://coloradofans.com/forums/385-2nd-gen-how-tutorials/352457-how-fix-ecu-rattle-firewall-diesel-canyon-colorado.html
Says its the ECU against the firewall. Some double sided foam tape does the trick
He said the rattle is on the driver side. ECU rattle comes from the passenger side, so I don think that’s the case here. Correct?
I also have a driver’s side rattle that the dealer hasn’t figured out after FIVE trips in. They finally gave up and told me it’s normal. It drives me insane.
I don’t know exactly where it is coming from but I know my passenger can hear it too. I will check the firewall tomorrow and report back. Thanks again
Could it be a rattle from the battery terminals? Kind of sounds like it
I think we have the same rattle. I thought maybe it was the strut loose underneath the battery. I feel your pain. Maybe we can figure this out together lol.
I’m going to get under the hood and underbody and check some things out today. I’ll post my findings.
Thanks for the tip friend....that fixed an annoying buzz that I have had for 2 years!
1 - 17 of 17 Posts
