Side Mirrors
1151 Views 7 Replies 3 Participants Last post by  Jrodrigues19
Hey I have a 2006 GMC Canyon,
I got these old Chrome 60s/70s side mirrors from a ford truck that bolt to the doors, I took off the stock side mirrors and just wondering if there is a cover that you can screw out inplace or if anyone has any ideas how cover the hole where the old side mirrors were.
Weird one
Thanks.
1 - 8 of 8 Posts
Delete--mis-read question. But if you haven't already drilled the holes in the door I would recommend the Boost mirrors instead.
See less See more
I already drilled holes, and the mirrors will look great on the truck, I might just fill and bondo it, thanks for the response
Could you just remove the mirror housing that flips in and then fill in the hole at the top of the little winglet that would remain?
I was thinking that, but I was trying to remove that piece but i think they are not made to be removed like that, There these plastic dowels that hold it together, very odd
Maybe just grind off the winglet and seal that up somehow. That would be a lot more noticeable though.
Have you removed the glass part of the mirror? I find it hard to believe you can't somehow remove that one part.
How about a rubber grommet (solid) thing that is used on firewalls or frames?
rubber grommet
Well its not just a hole, its the other side to the mirror assembly, Spray foam and Bondo anyone?? haha
1 - 8 of 8 Posts
