561 - 580 of 602 Posts
15" Tuff T04 wrapped in 31x10.5x15 Interco MT's. I forget the offset, but they stick out about 1/5 inches past my flare. They look perfect honestly. I wish 32's didn't kill my MPG so much
those are my pro comp 15 chrome wheels I can't tell the model or backspace :clueless
on 33" procom tires ill check the model later..
i.5" spacers tires where rubbing in front on the tabs
but even with the flares I installed the tires are out almost 2.5"
New wheel questions
Hello all looking at 16x7 or 16x8 in black like the craggar rims if possible. Not sure what will fit my z85 Ls 4x4 the best. I have a 3 inch lift level installed would like to run the cooper atr3 still they are great all around tires! Any recommendations would be great trying to stick to steel rims under 100 per
Thanks
I noticed no z71 OEM mud flaps on pictures with bigger rim such as 20s and 22s.
Do they need to be gone? If so, what is the biggest size wheel/tire we can use without removing them?
I'm going to buy wheels for my sons 2006 z71 4x4. It has 2" shackles and torsion bar crank. Looking at going with a set of xd spy wheels 17x9 with -12 offset or 4 1/2 backspacing and nitto 265/70/17. Most of the wheel places are saying this is too aggressive and i should go with a +18 offset. Will these work on this set up, not wanting to do any cutting but want somewhat of an aggressive look. What do you guys think and if you have this set up please post picture. thanks for you help
Super Moderator
because the torsion bars are cranked a +18 offset will probably rub the sway bar when turning sharp because the TB lift sucks the front tires/wheels in closer to the frame... the -12 offset will ensure no rubbing and put the tires/wheels about even with the large Z71 fender flares... shouldn't be any cutting or trimming needed with a 32x10.5" tire and a TB/shackle lift.... that is the stock tire size on 2009+ Z71's
I am looking at getting some aftermarket wheels for my '05 GMC Canyon Z71 4x4. I have been looking at some Pro Comp wheels. The Pro Comp Series 7069, 15x8 with 6 on 5.5 Bolt Pattern. The offset on them is -19mm. I am going to mount my tires that I have on my truck right now that are 265x75r15. Will these rims fit on my truck and those tires? When I get my next set of tires I am going to get either a set of 31x10.5r15 or 33x10.5r15. Does anyone have any advice?
Pro Comp Alloy Wheels Part 7069-5883 - Series 7069, 15x8 with 6 on 5.5 Bolt Pattern - Flat Black Machined - 4 Wheel Parts
15x8 with a -19 will protrude beyond the Z71 flares by about 3/4" of an inch. The wheel size is a good choice for both of the tire sizes you mentioned.
Most people go with a 4.5" max backspace, your suggested wheel is 3.8". The only draw back to it is that is puts extra force on the hub stickout. Many have it that way though. I personally don't like that look (too far out) but that's just my opinion).
This link can help you with the backspace values if you aren't very familiar with it.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
