1 - 7 of 7 Posts
Well that is not good at all. Some how water is getting back there. Hope not happening to mine.
That's not salt build up, that's aluminum oxide from the bracket.
- Pitting corrosion can occur if the aluminium is in a very damp environment where there are often salts present.
- For example, it occurs in common dirt and debris as well as in environments where the water cannot be led away from the metal.
Corrosion: Reasons and solution |
Great! Something else I have to check out now.
1 - 7 of 7 Posts
