1 - 6 of 6 Posts
Any one on here that has gotten a ss urethane rollpan care to share with me the paint process you went thru? I was just curious if the primer on it is good enough to scuff then base and clear or if it needed better primer or anything else done? Thanks in advance guys mine will be here friday and hoping for some info!
Thanks man. How was the fitment? Any issues at all otherwise? What type of sealer did you use?
It fits real nice. just followed the instructions,used cardboard as a spacer on each side and used self tapping screws along the top and a rivet on each side on the bottom tabs. Just make sure you leave your tailgate enough room to open without rubbing on the roll pan. I used dupont sealer since its readily available where I work, but any kind of sealer will work.
G
Guest
we use a adhesive promoter and a flex additive on all urethane parts and x2 on the pinholes!
1 - 6 of 6 Posts
