Hi All,
First, my appogies for such a long post.
I've spent a fair amount of time reading and reaching out to members on their setup and have completely confused myself, I think
I want to build up my Canyon AT into an overland vehicle and one of my main objectives is to run a 32.5 inch tire to maximize ground clearance. Since its multi use I want to try and maintain good road manners.
By reading the info here, it appears that the people running coilovers have also had to do a body lift or some sort of modification to the front wheel wells which adds to the overall cost. I definately want to add Superskidz #1 - 3, so those are already factored into my budget.
The Front:
From my reading, it seems that we need atleast 3 inches upfront to clear tires nearing or over 32 inches. I already have a Zone leveling kit and was wondering if I can combine that with something like the Eibach or Bilstein shocks set at 2 inches. That would give me 3.25 inches upfront.
Since the Zone leveling spacer sits on top of the assembly it wouldn't preload the shock. Would this work??? What other issues would this cause that I am not thinking of?? Is this approach just crappy or viable considering I need to retain decent road manners on pavement.
Alternatively I know AutoSpring has a 2.5" levelling kit and ICON's coilover system claims to have a 3 inch heigth setting...but the ICONs are darn expensive.
I would do a differential drop to relax CV angles and I beleive from reading that the AutoSpring diff drop still leaves enough room for a Superskid plate.
The Rear:
Can someone explain the pros/cons of a spacer block versus an add a leaf?? The spacer seems so simple in its solution, but my gut tells me to go with an add a leaf...I dunno why though.
If i can use the set up mentioned for the front, I beleive a 1.5 inch lift in the rear would be needed to keep things level. Is that a valid assessment?? I know that both Bilstein and Eibach offer rear shocks which are recommended for 0-1" lift. I assume I will need something else if I go to 1.5 inch in the rear???? Any recommendations on what I should be doing here?
Any info on pointing me towards a reasonably priced set up would be greatly appreciated. The 3 skid plates will be about $855 and I was hoping to get my ride all set up for $3,000 or less so that leaves about $2,200 for suspension and tires.
Thank you, George
The Front:
The Rear:
Thank you, George
