My truck - 06 Gmc canyon sle crew cab 3.5L
Hello everyone. So to start off I was had a problem with my truck just making that click noise when i tried to start it which ended up just being the terminals needing to be cleaned and tightened. Before doing that though I had tried jump starting my truck with a power pack and then trying to charge the battery for a little while(thinking the battery was dead). So after getting the truck started I noticed the radio not working. The fuse under the hood labeled RDO(15a) was still good, as well as the 10a fuse in the back of the radio still being good(btw all other fuses are good too). So then I tested the radio connector for power and ground with my test light and I had both. During that process I accidentally touched the power and ground together which blew the RDO(15a) fuse under the hood so I knew I was making a complete circuit. After replacing the fuse and checking again for power and ground to make sure I had got it back which I did, the radio was still not working. No other problems or lights on the dash are present and everything else works(lights, accessories, ect). I've heard some radio have a anti theft feature which will display "CODE" after a power outage but mine isn't doing anything. Could something else have happened while I was trying to jump start and charge the battery which caused the radio to fry out? I am currently trying to see if any of my friends have a radio laying around with the same power connector just to see if it works but nothing yet on that. Any suggestions? Thank you.
Btw the radio is a Pioneer AVH-P3400BH
