For all of you ext cab owners out there. Do you find that there is excessive door movement due to way the front doors latch to the rear doors? I've had my Colorado for for about 19 months and make frequent trips to my home in Joshua Tree where there are a fair amount of dirt roads. Under certain road conditions, there is so much movement that the doors make a flappy sounding noise. You can even see the movement. I've taken it to the dealer several times and they say that they cannot reproduce the effect and that they checked the latches and there is no adjustment. However, I noticed right after they "inspected" it, that all 3 bolts of the bottom latch of the rear door were loose. Tightening them helped quite a bit, but the movement still exists for both doors. I fear this is an engineering issue and that it cannot be corrected. Or perhaps the 2nd gen Colorado/Canyon was not tested enough. A couple of days ago, I just noticed that housing on both of these rods on the rear doors are cracked in half (see picture). Surely, this is a major concern.
