Never seen it done here in 3 years, and never seen it be able to be done in any of my past peasant grade GM vehicles: 05 Monte Carlo LS/08 HHR SS/11 Camaro LS/12 Camaro LT/12 Silverado LS/and current sig vehicles.Thanks. Maybe someone will figure this out!
Where is the so-called jack located that you would plug in the code reader for a 16 Colorado? Thanks for any repliesScantools and OBDII code readers are fairly inexpensive these days -- I have an Innova 3040C. Clears freeze frame data and also retrieves ABS codes.
The OBDII port is under the dashboard all the way to the left and above the parking brake.Where is the so-called jack located that you would plug in the code reader for a 16 Colorado? Thanks for any replies
Thank you I did some research and you're exactly rightThe OBDII port is under the dashboard all the way to the left and above the parking brake.Where is the so-called jack located that you would plug in the code reader for a 16 Colorado? Thanks for any replies
