1 - 20 of 26 Posts
2018 Colorado Z71, 3.6L V6, crew cab
Hey everyone.
I’m being sent away on business and won’t be using my truck for about 2 months.
Is there anything specific I should do to prep it for prolonged inactivity?
Thanks!
411161
2017 CCSB Z71
2 months isn't that long. About the only thing I might do is unhook the battery terminals and this should keep the battery from bleeding charge while you aren't using it. maybe a little bit of fuel stabilizer or something could help too
Connect a Battery Tender and be on your way. 2 months is nothing.
I wouldn’t disconnect the battery for two months inactivity, but you should put it in transport mode. This will turn off things which drain the battery but without resetting your clock.
I just recently restarted my Colorado after a five month hiatus, during which it was in transport mode. No battery tender, but I do have a new high-reserve battery.
Transport mode would probably be the way to go- or at least that’s what I would do (or wish I had done because it wouldn’t be smart enough to do this) these trucks never really turn off so something to prevent it from killing your battery would be good.
You could remote start it via your phone 2X a week too?
A Battery Tender will take care of everything for two months. I use one on my 02 Trans Am year and put maybe 300 miles per year. My last battery lasted 11 years 6 months.
yep, even with the battery disconnected it will discharge slowly. Lead acid batteries last longest if they are fully charged so a tender would be best.
But ya, 2 months in not that big of deal.
No, that's worse for the engine than just letting it sit since it produces condensation and won't get up to temp, let alone run long enough to boil off the condensation, etc. When a vehicle is being stored it should never be started unless it will also be driven for at least 30 minutes.
Battery tender is key since in newer vehicles complete lose of power (battery source) can cause in some to lose the firing order and other issues with the computer. That is why they have the memory saver for when you change your battery. It is not just for your radio stations.
I learned that the hard way with a 2005 Camry. Was told to change the battery while it was running. I did it the old trusty way. It took about a half hour of trying to keep it running before I coul ddrive again with out it dying.
This is the one I bought:
https://www.autozone.com/test-scan-...chumacher-obdll-memory-saver-cable/429081_0_0
and use a bettery jump box as the power source.
Schumacher Battery Extender 12-Volt 1,200 Amp Battery Jump Starter-BE01255 - The Home Depot
Reactions: LikeAnArcticRock
Most battery tenders are good I just happen to prefer the one named Battery Tender. When I had my 16 then 17 Shelby GT 350's sometimes in winter they would have to sit for a couple months out in the carport. I parked on cardboard to give some insulation between the tires and ground and would just hook up my Battery Tender. When ready to drive them unhooked it and they fired right up, with no problems what so ever. And believe it or not for such a high horsepower, high performance engine they take a rather small battery that have low cranking amps. And there were many times the temperature would be in the teens or colder to single digits.
The Battery Minder brand maintainers I have (3), used for many years. Bought them from Northern Tool.
I go on at least one 2+mo long trip a year for work. This is overkill but it's worked for me for 10+ years for 3 different vehicles. I use a battery tender plus.
(Not sure if the attachment is actually working on mobile)
Like others recommend...
  • Battery tender
  • Fill tank & add StaBil
  • Dryer sheets (all over), or moth balls
Should be good to go...FWIW, my Harley & Mustang sit covered for 5-months and always fire-up in spring. Only thing added to above is (1) oil/filter change, (2) tin-foil exhaust hole(s) & (3) good wash/wax. Cover them & sleep f/ winter.
This is not true and never change a battery while it's running. Whoever is telling you this stuff has no clue.
Memory savers are for radio stations and to keep the computer from having to relearn some settings, which they will in a short time.
Too many expensive electronic components on the new vehicles, makes disconnecting battery cables while running a very bad idea.
‘17 Colorado CCLB 2wd 2.8L Duramax Summit White
FWIW I’ve disconnected my battery for a 6 month stretch while on deployment. When I returned and reconnected the battery I didn’t lose any radio presets, trip meters, oil life or fuel filter life, or the clock. Truck fired right up no problems. I should mention I have the diesel with the original AGM battery.
Discussion Starter · #20 ·
Thanks everyone for the suggestions!
I had to leave on 24 hours notice, so I didn’t have time to get a tender or fuel stabilizer, but I definitely will for next time.
Ended up putting in in transport mode, as some suggested. No need for the wool or Bounce sheets as I live in the Arctic and we don’t have critters like that. Just gotta worry about the raven poop upon return haha.
Thanks again everyone! Really insightful! Appreciate everyone taking the time to read and reply!
1 - 20 of 26 Posts
