61 - 78 of 78 Posts
Since you have a wire, will a O2 sensor socket work?
Discussion Starter #62
Negative ghost rider. The oil lines cross right in front of the sensor but I think I can get a flex head ratchet on it. I’m going to pick one up and try
OK, Here comes the insensitive jerk question.
Are you getting engine codes? Can you just live with it until you know you have a problem?
Sorry if I missed something stated earlier.
But It seems to me, this could be a senseless exercise going from bad to worse, that didn't have to be done at all.
I just want the best for you brother.
If he is getting readings of 0 PSI oil pressure, and a message to shut the engine down, I would that is ground to attempt to correct the problem. I would think you would do the same.
What about removing the inner fender? It's a trick often used on the full size trucks, especially the diesel versions. Might give you room to work around the oil lines. Also, have you removed the big honking air chamber that covers the top of the engine? And I'm assuming you looked at trying from below. Sorry, but I'm too lazy to go out and look at mine for other ideas.
Too lazy to read the last few posts on the subject as well, it seems.
Discussion Starter #69
That’s not a bad idea tbh
Discussion Starter #70
But yea from the top is a no go since it sits fairly low on the block. It’s under the oil filter housing. From the wheel is the best bet. I think the ratchet is the best shot I have before I just unplug it and never worry about it again lol
Could you possibly reach it from underneath?
Take an Ohm reading on the sensor.
Tell us what you have.
Geez. I don't even have this engine and pressure problem, and I'm on pins and needles over here in Asia waiting to find out how this resolves!! Good luck with the sensor swap out.
Discussion Starter #74
Haha thanks man this weekend I’m going to give it my best shot replacing this thing. I think I have a plan. Will keep everyone posted.
Awesome! Happy that you got it fixed, and it was not expensive. Thanks for posting your results. That’s what the forum is all about.
Discussion Starter #77
Yea bro sorry for the delay. Working full time, full time grad school, managing my rental and a one year old boy means I have zero free time lol. I appreciate the support. Definitely nice to feel
we are all glad to help and really like to hear positive results.
61 - 78 of 78 Posts
