I've changed my oil twice, and I don't think I even got one drip out of the filter! I just loosen the cap while the oil is draining, and the filter housing will drain out also. Very slick system as far as I'm concerned.Pop your hood. Look over toward the right/drivers side right near the firewall next to the engine header area and you should see it. PITA to not spill a little oil when changing.
A lot less mess this way!Thanks
I appreciate it.
This is my first new vehicle. I am used to crawling underneath and changing a spin on.
funny, mines silver. bare aluminum 2016View of Filter Cartridge looking down.
Found another way to cut cost! My 2017 is definitely some type of plastic.funny, mines silver. bare aluminum 2016
well crap, they did it again. Well at least the truck is lighter now, probably gets better MPG because of it!!! yeah, rightFound another way to cut cost! My 2017 is definitely some type of plastic.
Not sure why you would waste money on the cap. The gasket, yes. But unless the cap is cracked and leaking, or you somehow managed to strip the threads there’s no reason to change it, it’s not a wear item.Well the advantage is AC Delco offers the filter carterage and also for just a lttle more a carterage and cap.
If that thing is a thin, cheap piece of plastic that is exposed to hot engine oil and underhood temps it will degrade over time for sure. Just like plastic radiators, they all crack eventually. That would be a very bad thing to fail, a nice big fire waiting to happen. I doubt I would replace it every time like a wear item but maybe after a few years for sure. Or like you said, if it was damaged somehow while removing/installing. Either way seems silly to use plastic to hold back 70 + psi of engine oil mounted directly over the exhaust pipe. Yikes!Not sure why you would waste money on the cap. The gasket, yes. But unless the cap is cracked and leaking, or you somehow managed to strip the threads there’s no reason to change it, it’s not a wear item.
Didn’t know they were plastic on the 17’s, mine is aluminum and won’t be replaced probably for the life of the truck lolIf that thing is a thin, cheap piece of plastic that is exposed to hot engine oil and underhood temps it will degrade over time for sure. Just like plastic radiators, they all crack eventually. That would be a very bad thing to fail, a nice big fire waiting to happen. I doubt I would replace it every time like a wear item but maybe after a few years for sure. Or like you said, if it was damaged somehow while removing/installing. Either way seems silly to use plastic to hold back 70 + psi of engine oil mounted directly over the exhaust pipe. Yikes!
Or just get one for a 2016 that is aluminum and be done with it, assuming of coarse it fits.
Anybody know where it is in the 2.5L 4-cyl engine?View of Filter Cartridge looking down.
I don't fault the guy for asking-I had to do some research here so I could find it! I looked all over the engine compartment for a remote spin-on...Again?
If you have to ask, you probably shouldn’t be doing it.
yes, if you were looking for a can type filter you would never find it!I don't fault the guy for asking-I had to do some research here so I could find it! I looked all over the engine compartment for a remote spin-on...
1st thing I wanted to know after I bought the truck! Not 1 of the parts stores I went into was even sure on the correct part number for the filter...Seems like if you went and bought the filter and oil you would discover pretty quick its a cartridge. lol
