1 - 20 of 26 Posts
· Premium Member
I started building my new bumper/tire carrier and thought I’d share a few photos during the process.
The stock bumper has actually been pretty durable but the hitch hangs down pretty low and has caused me issues off road.
Tire Wheel Car Vehicle Automotive tail & brake light
Automotive tire Bumper Gas Tints and shades Composite material
My design is pretty simple but should be really stout. I used 1-1/2 x 3 inch bar stock for the frame mounts. They will also act as my shackle mounts.
I drilled a few holes and spent most of my time this afternoon tapping them for 1/2-13 bolts. I also drilled a 1/2” hole that will go cross way through the frame. If you look close you can see it.
Automotive tire Table Red Bicycle part Gas
Automotive tire Motor vehicle Wood Automotive exterior Bumper
I’m using 6”x4” (3/16” thick) rectangular tube for the bumper. I’m going to cut holes in it and pass the bars through so they protrude out enough to add my shackles. I stopped for the day but my preliminary measurements show an approximate 7” difference in ground clearance.
Wheel Automotive tire Automotive lighting Motor vehicle Asphalt
Tire Wheel Automotive tire Vehicle Tread
Tire Wheel Car Vehicle Automotive tire
Obviously I have to cut the width of the tube but I’m going to mock up my spindle before I cut anything. It should take shape pretty quick if I can stay on task without life getting in the way.
Hopefully, I’ll get the holes cut for the bars to pass through tomorrow. 🤞
· Registered
Good work so far, that's going to be a massive bumper.
I'm surprised that truck looks so good underneath with it being 12 years old and the amount of off-roading you've done.
Reactions: WV NATIVE
· Premium Member
Discussion Starter · #4 ·
Thanks. I’ve tried pretty hard to keep the undercarriage clean - mostly due to my fear of frame rust. 😡
· Premium Member
With all the fabrication you've been doing, you're on track to do a tube chassis by 2025. 😂 Looks good so far! Can't wait to see the finished product.
· Premium Member
It is going to look great when done
Will make it a much better fit since you put it on solid axles
· Premium Member
Discussion Starter · #7 ·
I made some decent progress today. I managed to get the “pass through” cuts finished. The idea is simple but the execution was harder than you’d think.
Everything lined up fairly tight. A couple gaps are bigger than I’d like but they’ll still weld up.
Automotive parking light Tire Wheel Car Vehicle
Wheel Automotive parking light Tire Vehicle Motor vehicle
The receiver hitch was the same pass through cut and wasn’t too bad to get lined up. Unfortunately the tube I bought was too short so I have another one ordered.
I’m hoping to mock up the spindle and cut the extra length off the bumper tube tomorrow or possibly the day after. 🤞
Automotive parking light Automotive tail & brake light Vehicle Car Tire
Automotive parking light Automotive tail & brake light Tire Vehicle Wheel
My ground clearance has improved significantly.
Wood Gas Tints and shades Font Fender
· Premium Member
Discussion Starter · #8 ·
I cut the passenger side of the bumper down to it’s finished length and got the holes drilled for the spindle.
Wood Bumper Automotive exterior Gas Hardwood
Automotive tire Automotive lighting Floor Gas Flooring
I got the 7 way plug holes cut and tapped the the bolt holes. It turned out pretty good.
Wheel Tire Vehicle Car Automotive tire
I’d like to get the swing arm notched for fitment to the spindle tomorrow. I may go ahead and weld it up but I can’t finish the arm until my latch arrives in the mail. I’ll cut down the driver’s side of the bumper to length after I finish the latch design.
Hood Automotive tire Automotive lighting Automotive design Motor vehicle
· Premium Member
Discussion Starter · #9 ·
I took a break and spent some time with my kid this afternoon. She’s on spring break and was just sitting around.
I don’t like spending so much time in the garage when she’s available to hang out with me. She doesn’t share my passion for tinkering unfortunately.
We talked and joked for a while and I waited for her to go to bed before tackling one last thing on my project before I call it for the day.
I notched the swing arm bar for the 3” spindle housing. I’ve never really notched tube before so it was an interesting experiment.
I’m not an expert but I’m pretty happy with the results. I’m hoping to get the spindle welded in the bumper and the spindle housing welded to the swing arm tomorrow.
I laid out some pieces of scrap so I can practice laying down a few beads before I trust myself. You gotta remember that I’m not a fabricator - I am just a hobbyist.
Hood Automotive lighting Automotive design Automotive tire Bumper
· Premium Member
Discussion Starter · #10 ·
Today was a good day for progress. I got the spindle welded in and pretty much got the swing arm built.
I’m expecting my latch to be delivered tomorrow. When it arrives I can figure out what length I need the swing arm to be. Cutting it to length will not take long but I’m cautious about cutting anything too soon.
The post that the tire mounts onto is obviously too long. I’ll mock up my tire and cut it to length once I get the mounting plate built.
The swing arm is really smooth and everything seems to be working perfectly. I’m excited for another fabrication day tomorrow.
Tire Wheel Automotive tire Motor vehicle Automotive design
Tire Wheel Land vehicle Cloud Car
· Super Moderator
Damn dude.
Your truck is going to be what alien archeologists discover in a millenia when humans are extinct, and I'm happy to think they'll assume we all had rigs like it.
· Premium Member
Discussion Starter · #12 ·
Damn dude.
The more intelligent archeologists will come to understand that there simply wasn’t any off-road aftermarket for the 1st Gens so a fella had to take matters into his own hands. 😆
Seriously though - I built the the tire carrier to handle up to a 40” tire. After seeing your Florida pics I really want to stuff some larger tires on my truck. Your truck looks absolutely perfect with that set up.
I can easily fit some 35s and I just might look into a set now that I have a place to carry the spare. 🤔
· Premium Member
Discussion Starter · #16 · (Edited)
Today was rather frustrating for some reason. Everything seemed to fight me every step of the way.
I got the spare tire mounting plate built. I made 4 trips to the auto part store trying to find lug studs that would work. Eventually the staff just told me to take whatever I wanted and pay for it later. 😆
Now’s the part where I show just how stupid I am. In the picture you can see a distinct heat mark just below the last “O” in Colorado. I had to heat and bend the swing arm. When I welded up the A frame for the tire mount I used a C clamp to hold the swing arm end. It never occurred to me that the heat would warp the tube as much as it did. I removed the clamp and saw the warpage. 😢
I had to heat it and red-neck a harbor freight pipe bender on the arm to bend it down to a point where it’s less noticeable. Now my swing arm has a kinda dog leg but at least it looks better. 🤷🏻‍♂️
Anyway, after “solving” that issue I moved forward and got the latch installed. My design is pretty simple but still required a ton of fitment to get everything to clear.
I built a ramp for the swing arm to sit on so it would keep pressure off the spindle. I used a low profile bump stop as a backer for the swing arm to hit. It barely drags across the ramp before it touches the bump stop. 🙏
Gas Auto part Metal Machine Composite material
Wood Machine tool Gas Machine Metal
I bolted up the latch I decided to use. It’s a Destaco 344-R. I’m not exactly thrilled with the location of the latch clip (whatever you call it) on the outside edge of the bumper but it’s all I could think to do.
Automotive tire Automotive lighting Motor vehicle Bumper Automotive design
Automotive tail & brake light Automotive parking light Automotive lighting Drinkware Fluid
This is where I decided to stop for the night. It’s nearly 0100 hours and I’ve not had any supper yet.
Tire Wheel Land vehicle Car Vehicle
· Premium Member
Now’s the part where I show just how stupid I am. In the picture you can see a distinct heat mark just below the “O” in Colorado. I had to heat and bend the swing arm. When I welded up the A frame for the tire mount I used a C clamp to hold the swing arm end. It never occurred to me that the heat would warp the tube as much as it did. I removed the clamp and saw the warpage. 😢
View attachment 443917 View attachment 443918
Awesome Job
· Registered
LOL - you're going to need air bags to correct the sag from all that extra weight, but rear wheel traction ought to be considerably better! Having said that, I've always over-engineered. It was a lesson I learned as a die maker for GM. What are the plans for finish - powder coating, paint or bed liner? I'm thinking combo of paint and bed liner.
· Premium Member
Discussion Starter · #19 ·
Yeah it’s definitely overbuilt. I’ve still got to cut the main support bars to length so hopefully that will shed about 20 pounds.
I see a lot of Overland bumper systems out there with tires, racks, ladders, tanks, etc….and I can’t imagine how much they weigh.
As far as painting I’m going to just shoot mine with some Herculiner. I’m not much of a painter and that stuff is pretty forgiving regarding the application process. It’s also nice if random touch ups are needed. I’m definitely function over form (as if you guys didn’t know that already). 😉
I’m at the part in this project where the nitpicky stuff is coming into play. I need to mount my license plate and find a way to illuminate it. I’ve got to engineer a way to hold open the swing arm. My rear view camera is now blocked by the tire so it’s gotta be relocated. It’s still a long way from being finished.
· Premium Member
Discussion Starter · #20 ·
I got all the open ends capped today and finish welded the hitch in position. I tapped the receiver hitch for an anti-wobble bolt and it turned out good. I tried to be smart and only use the same size bolts for everything so all I’ll need is a 1/2” wrench for the latch system and hitch.
Overall it’s been a pretty easy day. The hardest part was finding enough scrap metal laying around to make the end caps.
I had hoped to take the frame bars to the machine shop down the street but they were closed for some reason.
I need the machine shop to bore the hole for the shackle pins. I don’t have the capacity to drill a hole that large. I guess I’m on hold until Monday….at least I assume they’ll be open Monday. 🤷🏻‍♂️
Wood Gas Bumper Machine Cameras & optics
Automotive lighting Bumper Material property Automotive exterior Gas
Automotive tire Motor vehicle Bumper Asphalt Fender
Automotive tire Tire Asphalt Bumper Road surface
Wood Automotive exterior Gas Bumper Machine
Hood Bumper Automotive exterior Motor vehicle Wood
1 - 20 of 26 Posts
