2017 Colorado Crew Cab 4WD w/ V6, 100K miles on the clock. Recently there are two things that I suspect are related:
1) The temperature gauge stays at the lowest point in spite of the engine warming up enough that the heater blows hot.
2) The radiator fan comes on and runs for 5-10 minutes after I park when I don't think it should. Like when it's quite cool out and I've only driven a short distance. In the past I only noticed it running when it was very hot out and I had been using the A/C.
I checked the coolant and coolant levels and all look to be normal. Nothing odd about the radiator hoses or heater lines that I can detect. Engine or radiator don't seem to be overly hot (i.e. no coolant spurting into the overflow tank) and everything else seems normal.
Thoughts?
Thoughts?
