good day all,
I just had the CEL come on, on my 2106 gmc canyon 4 wd 2.5l extended can pickup. just turned over 100k
been good all along other then a reprogram for an idle shutter at stops, intermediately, a few other maintenance things,
and a rear water outlet on the block/head that was leaking at temp sensor and hoses that I replaced.
I baby the hell out of this thing as I worked long and hard to save up to buy new with cash.
Its been awesome all along but just about 1 week ago,
about 0 degrees out driving for about 1/2 hour then the CEL came on:
ran no different. no smell of fuel.
got home scanned and codes came up as:
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit
so I checked the fuse under hood for EVAP canister vent, fine.
I checked electrical connection plug to the canister vent, fine
replaced vapor canister purge valve under the hood
replaced canister vent valve solenoid
check over lines to and from tank, canister, and engine best I could without removing tank
replaced fuel cap
removed and checked over canister for any cracks leaks and all connections etc.
cleaned canister filter foam
I can reset the light, with my scanner but as soon as I turn truck off and restart the CEL doesn't turn off after start up like it normally would but remains on, when i scan I get the same two codes over and over :
any thoughts, help, similar issues or suggestions would be appreciated.
replaced fuel cap
