1 - 8 of 8 Posts
Above the glass in the rear is a light (reverse/brake) the plastic is all yellowed out. Possible to change out myself? I’m not having luck finding my 06 2 door out here in central Florida. Anyone have a link? Or name for that piece to find myself?
Third brake light
Typically 2 screws and an electrical plug easy swap out.
May want to seal it with a small bead of silicone. They have been known to leak easily.
If you put a new on on sand the raised area by screw holes a bit so it will line up flat and flip with a bead of black silicone around it. It will go with the flow of the truck and look better and seal better with less chance of leaking. Also run a bead across the top.
here one for $108.37 & $8.00 SH https://www.gmfactorypartsonline.com/oem-parts/gm-high-mount-lamp-25971002
$106.42 + $8 SH https://www.gmpartsguys.com/oem-parts/gm-high-mount-lamp-25971002
I have tried those Cheap aftermarket ones there garbage I was lucky last year i found A Brand New In Box Genuine GM On Ebay for $70 just looked cheapest now i see is $121.94
https://www.ebay.com/itm/GM-OEM-3rd-Third-Brake-Light-Lamp-25971002/131957527441?hash=item1eb9481391:g:-tgAAOSwXetZRCKp:rk:2:pf:0
Just called someone i know who just bought one 3 months ago he got this one & so far its been ok but its only been 3 months the aftermarket ones i tried all got water in them after about 8-10 months that's why i bought a Original one.
[ame]https://www.amazon.com/Chevy-Colorado-Canyon-Chrome-Smoked/dp/B07H3NSXWR?th=1[/ame]
Dorman or TYC don't make a OEM Replacement
1 - 8 of 8 Posts
